Author Topic: Waterloo  (Read 19453 times)
Re: Waterloo
« Reply #53 on: April 03, 2015, 03:35:10 PM »
Just try to think of this: "Light comes from the shadow"
fesak_j
Re: Waterloo
« Reply #52 on: April 03, 2015, 03:20:25 PM »
thanks for tips, lads  :)
i was wondering how deep shadows/ better to say the contrast/ should be?
this is my first two projects ever with flatd, i tried 4 round figures before just to touch oils & acrylic paints  :)  ....in the next project i will be more softer with highlights & shadows.....
Re: Waterloo
« Reply #51 on: April 03, 2015, 11:38:32 AM »
Nicely done, but I agree with Eric in that the shadows need more contrast. Part of that is because it's difficult to discern the specific light direction. For the most part it seems to be washing down from above and front but certain areas that should be in shadow are not (the upper under the hat brims and the area under the left figure arm for example). Other parts - cannonball, left figure leg wrap, and right figure shako - indicate above left front; while the drumhead and bare knee seem to indicate above right front. Still trying to get this right myself, so I tend to look for it...
Re: Waterloo
« Reply #50 on: April 03, 2015, 08:38:30 AM »
Nicely done but lacking some contrast
You should accentuate the shadows
But probably the picture does not help the appreciation
fesak_j
Re: Waterloo
« Reply #49 on: April 03, 2015, 02:34:09 AM »
finally both with background  :)
fesak_j
Re: Waterloo
« Reply #48 on: March 24, 2015, 04:49:12 PM »
act. progress  :)
fesak_j
Re: Waterloo
« Reply #47 on: March 18, 2015, 03:16:18 AM »
another waterloo tribute in progress :)
Re: Waterloo
« Reply #46 on: March 03, 2015, 11:24:28 AM »
Ditto! All it needs now is the smell of burnt gunpowder.  ;)
Re: Waterloo
« Reply #45 on: March 02, 2015, 05:06:21 PM »
Much better !
fesak_j
Re: Waterloo
« Reply #44 on: March 02, 2015, 02:21:39 PM »
pic below :)
fesak_j
Re: Waterloo
« Reply #43 on: March 02, 2015, 02:05:27 PM »
so i added some more shadows and captured the flat under different position to light from bulp  :)  ......
glen: bricks  ;D  that costed my a lot of nerves i have painted almost each one of them separately....i added some shadows also behind the soldiers
Re: Waterloo
« Reply #42 on: March 02, 2015, 12:03:00 PM »
It's coming along nicely, but I would agree with Eric; more shading is needed especially on the wall and gates behind the soldiers. The representation of the brick and wood is excellent, but there are different angles to all of them. Shouldn't the highlighting and shading be a bit different as well?
Press on!
fesak_j
Re: Waterloo
« Reply #41 on: March 02, 2015, 07:14:31 AM »
thank you brian  ;)
eric, nicholas: thank you for advice, I will wait a while till the ground will be more dry and I will add more shadows directly under the men and lightly more around.
Re: Waterloo
« Reply #40 on: March 02, 2015, 07:05:16 AM »
That's worked out very well, as Eric said, maybe a few shadows, but even so nicely done ;)
Re: Waterloo
« Reply #39 on: March 02, 2015, 04:34:26 AM »
Very well painted!!  you did good there Jozef, well good ;D ;)
