Author Topic: to Marco  (Read 11319 times)
Re: to Marco
« Reply #16 on: October 17, 2014, 05:23:15 PM »
Holy fecal material!   :-[
I just found that little white down arrow at the top right of the screen!  :o
NOW I see them.
Re: to Marco
« Reply #15 on: October 17, 2014, 05:18:16 PM »
I usually view from a desktop, and I do not see the unread posts column.  Just the new posts - which contains only one post.
I've been going to the View Most Recent Posts at the bottom of the page to scroll thru and find the ones I have not read that are not in New Posts.
(Signed)
Confused in the States  ;D
Re: to Marco
« Reply #14 on: October 15, 2014, 12:42:21 PM »
I think you've hit the nail on the head there Glen.
Re: to Marco
« Reply #13 on: October 15, 2014, 11:19:30 AM »
If I may weigh in... I primarily use my desktop computer to view the internet. Occasionally, I will use my wife's Nook. I've found the tablets and readers often do NOT view the interweb the same way as a dedicated computer. Formatting is often different and peripheral sidebars may be absent as well. I don't think there is an internationally recognized fix for this (yet), since readers and tablets are not fully standardized.
Jus' sayin'...
Re: to Marco
« Reply #12 on: October 15, 2014, 12:41:53 AM »
It's still the same Mark. It's obviously something to do with the devices Eric and I are using. I'm sure we will cope, thank you for trying to help.
Re: to Marco
« Reply #11 on: October 14, 2014, 08:01:08 PM »
Ok one more try - what about now?
mark  :o
Re: to Marco
« Reply #10 on: October 14, 2014, 03:45:13 PM »
Same too
Re: to Marco
« Reply #9 on: October 14, 2014, 03:24:22 PM »
Nope, just the same.
Re: to Marco
« Reply #8 on: October 14, 2014, 03:19:15 PM »
How about now - have you seen a reappareance?
Re: to Marco
« Reply #7 on: October 14, 2014, 03:03:48 PM »
Same problem as Roger
The "new posts" column does not appear in item 2
Re: to Marco
« Reply #6 on: October 14, 2014, 02:28:49 PM »
Item 1 is working fine as is Item 2, however there is not the New Posts menu on my Kindle. Not to worry though it's not a massive problem and thank you for taking the time to try and sort it out Mark.
Re: to Marco
« Reply #5 on: October 14, 2014, 01:49:03 PM »
That works tell me how this works.
This is how my screen looks - a little different from your but, close
You will note I here I have marked an item 1 and item 2
If you click on Unread Posts - item 2 here it should show you posts you have not read yet, i.e. new, for the Current Topic.  If you click it a second time it will show you Unread Posts from the Entire site.
You will also note an item 1 in the upper right hand corner which is a carot that looks like V.  Click on the carot and you should see it turn ^ and in the left hand corner you should see the following:
Let me know if either of these changes work.
Re: to Marco
« Reply #4 on: October 14, 2014, 11:52:02 AM »
I don't know how to do a screen print on Kindle or even if it's possible so I took a photo instead.  ;D Hopefully you can see what we mean and it is useful.
Re: to Marco
« Reply #3 on: October 14, 2014, 11:20:04 AM »
I don't have either of these devices which makes it tougher to diagnose these kinds of issues.  Can one of you send me a screen print of what you are seeing please?  I do have theory but, tough to validate without being able to see it.
cheers
Re: to Marco
« Reply #2 on: October 14, 2014, 03:54:48 AM »
I just got home yesterday and noticed this too. I have the same problem as Eric when viewing on my Kindle but on my laptop it is fine and showing both New and Unread columns.
