Author Topic: WW II Aircrafts  (Read 14874 times)
Re: WW II Aircrafts
« Reply #25 on: August 06, 2014, 12:08:49 PM »
Another success Jan looks great.
John R
Kulmbach
Re: WW II Aircrafts
« Reply #24 on: August 06, 2014, 11:46:08 AM »
Test
Re: WW II Aircrafts
« Reply #23 on: August 05, 2014, 12:10:43 PM »
How did you do the markings and Mickey on the other plane Willie
Re: WW II Aircrafts
« Reply #22 on: August 05, 2014, 12:01:32 PM »
Nicely done; especially the dappled camouflage! The markings, cockpit details and glass depictions are top-notch, but might the front glass panes be a bit different in tone due to their changes in angle?
Probably a bit late, but I think there should be more shading and highlighting on the fuselage side to denote the sharply curving bottom transitioning to the gently curving side transitioning to sharply curving top. Think of an egg standing on its large end.
The prop shadow is a nice touch, but the 109E exhausts were nestled inside a fairing that shrouded the exhausts top and bottom. There should be a long shadow line under the fairing with perhaps the very tips of the exhausts creating another shadow beyond that.
Perhaps a highlight bump on the intake, the fuselage spine, wing tip, and the leading edges wing, tail-plane, and vertical fin/rudder is in order as well. Even matte finishes produce a highlight sheen on acute angle changes.
There's a few more, but I've probable pissed you off enough as it it is... ;)
Re: WW II Aircrafts
« Reply #21 on: August 05, 2014, 03:50:59 AM »
Big thumbs up with this one as well ;) :)
Re: WW II Aircrafts
« Reply #20 on: August 04, 2014, 09:24:33 PM »
Very nice job  Willie. Was that painted in oils?
Re: WW II Aircrafts
« Reply #19 on: August 04, 2014, 05:25:43 PM »
Very glad you persisted.  It is really a first class paint job, beautifully done.
Kulmbach
Re: WW II Aircrafts
« Reply #18 on: August 04, 2014, 04:42:54 PM »
Finely I managed to post "Gruppenkommandeur" Helmut Wick´s aircraft!
Jan
« Last Edit: August 04, 2014, 05:27:43 PM by marko92 »
Re: WW II Aircrafts
« Reply #17 on: June 15, 2014, 12:44:29 PM »
Ah... that makes it closer to 1/72 versus 1/48. Say mid 1/60s scale. A good size for WW II fighters.
nmrocks
Re: WW II Aircrafts
« Reply #16 on: June 13, 2014, 07:49:19 PM »
Thanks Jan and Glenn, just what I need... to expand my flat interests!!!!!    :P
Ray
Kulmbach
Re: WW II Aircrafts
« Reply #15 on: June 13, 2014, 08:38:51 AM »
Scale or no scale ... referring to Jacques Vullinghs they are matching a 30mm figure.
Jan
Re: WW II Aircrafts
« Reply #14 on: June 12, 2014, 11:57:30 PM »
It was pointed out that the Spit was 160mm long. That's around 6.25". A 1/48 Spitfire I is around 7.25", so off the top of my head the flat is coming in somewhere in the low/mid 1/50s in terms of scale. I'd do the math, but it's late and I'm tired...
nmrocks
Re: WW II Aircrafts
« Reply #13 on: June 12, 2014, 09:10:50 AM »
These are really great castings and the detail you add looks like a photo, great work! what is the size/scale?
Ray
Re: WW II Aircrafts
« Reply #12 on: June 05, 2014, 11:14:07 AM »
Jan it seems you have far steadier hands than I do  :o .
I would have to uses masking tape, stencils, or decals to get them to look that good.
I'd like to see the other aircraft when you get to them.
Kulmbach
Re: WW II Aircrafts
« Reply #11 on: June 03, 2014, 06:29:53 PM »
For your information Glen, everything is painted and there isn´t any guide lines engraved, which I am glad for.
I have a couple of more painted German aircrafts which I will show when I have become on friendly terms with my computer again.
Jan
